1 Reply Latest reply on Nov 5, 2012 12:37 PM by Glenn Schroeder
    Unable to save file as a PDF
    David Eytchison
      I have one machine that can save some parts as PDF files but then the next part will not save. It does not give any errors, it acts like it is saving and then does nothing. I have tried saving to the network drives and to the local PC but they both work the same. I can go to a different PC running SolidWorks 2012 and pull the file from the vault and it will save as a PDF without issue. I have tried rebooting but that does not help. The only difference between the two PCs is that one is running SolidWorks 2012 SP4 (the one that will not save certain files) and the other is running SolidWorks 2012 SP2. Has anyone come across this issue? Any idea as to the cause of this issue?
