We are trying a surface body to a solid. The surfaces of the surface body were imported from ICEMCFD. When we try to form a solid it fails and says that there are open surfaces. The model is a fan blade with some modifications to the trailing edge. COuld someone give us some tips to successfully generate the solid body from the surface body.
Viswanath,
Welcome to the forum
The imported surface quality is very bad. I tried to fix it in SW and gives error.
I tried even other programs, gives the same result.
How did you import into SW?
Can you post the original file?
JOHN
