I want only to limit access to a tab depending on the user group.
I tried and it does not work the way I expected.
I thought that I could apply the control of tabs unique from each other (one tab "Show tabs" and the rest "Controlled by variable"), but I soon discovered that the all the tabs on a datacard are either "Show tabs" or "Controlled by variable".
I also that that I could pick the group name from the drop down but that was not the case, the dropdown only offers <Name of Group>.
I also think that the Tab name must be an actual group name!
I also assumed that when <Name of Group> equalled the group of the user then the tab would be visible, other wise it would be hidden from the user.
Can anybody clarify some of these points for me?
Thank you,
Gary.
Dear Gary,
Yes you are correct, The name of the tab should be the same as the group name. And if you use Controlled by variable option for tab, based on the users group the tab would be highlighted.
Hope this helps !
Regards,
Raghav.
