3 Replies Latest reply on Nov 2, 2012 4:22 PM by Keith Rice
    How to delete a BOM Table from a Part Doc using API?
    Steve Fye
      I would like a macro that can do the following:
      1.  Inserts a BOM table into a PART document
      2.  Exports it as text
      3.  Deletes the table created in step 1
      I have done everything successfully except for step 3.  I am pretty sure that I'm close to the correct answer, but I haven't quite got it.  Here's my code (removed some items for clarity).
      How the heck does one *get* the table so it can be deleted?  I don't want the user to be required to select it.
      Private Sub MyMacro()
                Dim swModel As Object
                Dim swBOMTable As Object
                Set swModel = swApp.ActiveDoc
           'Set swBOMTable = swModel.Extension.InsertBomTable(<deleted this for forum post - it works>)
           'retval = swBOMTable.SaveAsText(<deleted this for forum post - it works>)
      'Here is where I think it's going wrong.
      'The following code executes, but retval returns FALSE
      'How do I select the table automatically so that I can delete it?
                retval = swModel.Extension.SelectByID2("", "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0)
      'The above line always returns FALSE
                swModel.EditDelete
        • Re: How to delete a BOM Table from a Part Doc using API?
          Keith Rice
          Hi Steve,
          Try this:
          Dim swFeat As SldWorks.Feature
          Dim swSubFeat As SldWorks.Feature
          Dim swBomFeat As SldWorks.BomFeature
          Dim vBOMTableAnns As Variant
          Dim swBomTableAnn As SldWorks.BomTableAnnotation
          Dim swTableAnn As SldWorks.TableAnnotation
          Dim swAnn As SldWorks.Annotation
              Set swFeat = swModel.FirstFeature
              Do While Not swFeat Is Nothing
                  If swFeat.GetTypeName2 = "TableFolder" Then
                      Set swSubFeat = swFeat.GetFirstSubFeature
                      Set swBomFeat = swSubFeat.GetSpecificFeature2
                      vBOMTableAnns = swBomFeat.GetTableAnnotations
                      Set swBomTableAnn = vBOMTableAnns(0)    'assume only one BOM table
                      Set swTableAnn = swBomTableAnn
                      Set swAnn = swTableAnn.GetAnnotation
                      swAnn.Select3 False, Nothing
                      swModel.EditDelete
                      Exit Do
                  Set swFeat = swFeat.GetNextFeature
              Loop
          Also, some macro writing advice:
          1. Use "Set swApp = Application.SldWorks" instead of "Set swApp = CreateObject("SldWorks.Application")". The latter is archaic and I have seen issues with macros not running until it is changed to the former.
          2. Instead of declaring SolidWorks objects as Object, declare them according to their specific object interface. For example, "Dim swModel As SldWorks.ModelDoc2". This allows for you to use Microsoft Intellisense when writing code and will make your life a lot easier. If you want to see a video tutorial that demonstrates early binding and much more, check out Lesson 2.2 here.
          I hope this is helpful!
          Keith
          Video Tutorials for the SolidWorks API
