2 Replies Latest reply on Nov 2, 2012 5:04 PM by Dan D
    Slow selection performance
    Dan D
      I am using SW2013 (although i had the same issue with SW2011 as well)
      My test bench, to describe the problem, consists of a cilinder and a sweep extrude, in his case a helix as can be seen below.
      For some reason when i select the helix, or hoover over it, it takes a very long time for the display to show it as selected.
      Instead of showing is all selected at once i can see the selection creeping up the helix until it is fully selected.
      Also, if i keep the mouse over the helix it keeps selecting it and reselecting it.
      What can i do to check the problem?
      I changed what i could with the performanc optiones but it did not help.
      an it be something with windows itself?
      Intel Core i5-3450 3.2GHz
      8GB RAM
      win7 64
      I have asus MB and i am using the graphic of the i5 core processor.
      Though I do not have a high end system, for the small part i described above i should have no issues, or should I?
      Can the graphic card be the problem? even for such a simple assembly?
      Thanks....
