hi everyone!
I am designing a Scissor lift on solidworks. On assembly, I added a concentric and co-incident mate between two beams so they were aligned. The next thing was I wanted my beams to move 45 degree apart. For that I used the Limit Angle mate and set the limit to 45 degrees (I selected the two top faces of the beams). Now the problem is that when I try rotating my beams only one beam rotates whereas the other beam is afixed to its position! I also want that beam to rotate as we have in scissor lifts. Can anyone tell me how do I correct this?
I am looking for this type of mechanism between the beams as in this video.
http://www.youtube.com/watch?v=8zAqFCuQJB4&feature=related
Thank you
Waiting for replies
Rizwan, is the beam that is not moving the first part you brought into the assembly? If so it is a fixed component.
