Macro for Creating New Layers and Moving dims/annotations onto the New Layers
Brett Hausler Nov 2, 2012 12:02 PMWhat I am trying to accomplish is to create four new layers on an existing SolidWorks drawing. Once I have these layers I want to move all the dimensions on the sheet(s) onto one layer, tables onto another layer, other annotations onto a third layer, and the title block and border onto a forth layer. I also want to change the document properties so new dims/tables/annotations will automatically go to the correct layer.
So far I have been able to find enough info to help me get the new layers added, the dimensions onto the Dimension layer, and the document options changed.
I still need to move all annotations onto an Annotation layer, tables onto a Table layer, and the title block/border, onto a Title Block layer.
Below is the code I have so far. Any help on this would be great!
Brett
Dim swDwg As SldWorks.DrawingDoc
Dim swLayerMgr As SldWorks.LayerMgr
Dim AnnoLayer As Integer
Dim TblsLayer As Integer
Dim DimsLayer As Integer
Dim TitleBlockLayer As Integer
Dim boolstatus As Boolean
Dim i As Integer
Dim NumShts As Integer
Dim swView As SldWorks.View
Dim swAnn As SldWorks.Annotation
Dim swDispDim As SldWorks.DisplayDimension
Dim swAnno As SldWorks.Annotation
Set swDwg = swApp.ActiveDoc
Set swLayerMgr = swDwg.GetLayerManager
AnnoLayer = swLayerMgr.AddLayer("Annotations", "Annotations Layer", 968742753, 0, 0)
TblsLayer = swLayerMgr.AddLayer("Tables", "Tables Layer", 968742753, 0, 0)
DimsLayer = swLayerMgr.AddLayer("Dimensions", "Dimensions Layer", 968742753, 0, 0)
TitleBlockLayer = swLayerMgr.AddLayer("Title Block", "Title Block Layer", 968742753, 0, 0)
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingNote, "Annotations")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingBalloon, "Annotations")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingBendTable, "Tables")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingLinearDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingDiameterDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingRadiusDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingHoleDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingAngleDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingChamferDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingOrdinateDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingDatum, "Annotations")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingSurfaceFinishSymbol, "Annotations")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingGeometricTolerance, "Annotations")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingWeldSymbol, "Annotations")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingBillOfMaterial, "Tables")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingRevisionTable, "Tables")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingGeneralTable, "Tables")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingHoleTable, "Tables")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingArcLengthDimension, "Dimensions")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingPunchTable, "Tables")
boolstatus = swDwg.Extension.SetUserPreferenceString(swUserPreferenceStringValue_e.swDetailingLayer, swUserPreferenceOption_e.swDetailingWeldTable, "Tables")
NumShts = swDwg.GetSheetCount
For i = 1 To NumShts ' blindly go to the first sheet
swDwg.SheetPrevious
Next i
Set swView = swDwg.GetFirstView
While Not swView Is Nothing
Set swDispDim = swView.GetFirstDisplayDimension
While Not swDispDim Is Nothing
Set swAnn = swDispDim.GetAnnotation
swAnn.Layer = "Dimensions"
Set swDispDim = swDispDim.GetNext3
Wend
Set swView = swView.GetNextView
Wend
swDwg.SheetNext
Next i
