Hello all,
I have an assembly including many other sub-assemblies. I do the following actions:
* mofidy the assembly of its sub-components
* save all open components
* get out of solidworks (close SW)
* reopen my initial assembly (without doing anything else)
then in this case SW asks me to save the assembly and other sub-components as well - although I have not changed anythings. I am not sure I understand the logic behind SW, someone does or is this some SW weirdity?
Subsidiary question: when opening a component, is there a way to open all the sub-component it contains at the same time? I have quickly looked for this both in SW and on the web and could not find...
Antoine.
Antoine,
This may be an indication that some of your components are defined by in-context relations. SolidWorks is not particularly good at keeping track of whether or not something has been changed, seeming to think that if there is any possibility that something could have changed, then it should assume that it did change.
Jerry S.
