3 Replies Latest reply on Oct 31, 2012 4:22 PM by Aj Jones
    A Couple Of Debugging Questions In VB.NET
    Aj Jones
      I'm copying code from a VB Macro I wrote and putting it into vb.net using MS VS 2012 Express.  I went through a lot of the macros made by SolidWorks and then once I got certain things to work in .NET, I tried converting the whole code. A lot of the errors I have been able to fix, but a few things I still have questions on, and I was wondering if anyone knew what needs to be fixed.
      The two things I have imported into the project are:
      Imports SolidWorks.Interop.sldworks
      Imports SolidWorks.Interop.swconst
      --- For one thing, anything with   swApp = Application.SldWorks   seemed to error out.  From the looks of it, and looking at other VB.NET code this is not needed in VB.NET correct?
      ---  When selecting a plane the "swThisConfiguration, Empty" part gets an error stating it is not declared and that it may be inaccessible due to its protection level.
      boolstatus = swModelDocExt.SelectByID2("FrontPlane@" & PartName, "PLANE", 0, 0, 0, False, 0, Nothing, swSelectOptionDefault)
      swDim = swModel.Parameter("D1@CL OF FRONT OR@" & PartName & ".SLDASM")
      dimValue = swDim.GetSystemValue3(swThisConfiguration, Empty)
      --- When checking that the document is an assembly I get an error for the <> part of the document "Overload resolution failed because no accessible '<>' can be called within these arguments
      If Model.GetType <> swDocASSEMBLY Then
      Also getting errors for anything ending with "Empty" saying System.Empty is not accessible in this context because it is 'Friend'.
      Part.Extension.RunCommand(swCommands_SaveAs, Empty)
        • Re: A Couple Of Debugging Questions In VB.NET
          Michael Jeffries
          Use the following instead of "swApp = Application.SldWorks:
          swApp = New Sldworks.Sldworks
          or
          swApp = CreateObject("Sldworks.Application")    'Though I prefer the New Sldworks method
          Try the following:
          1)
          If Model.GetType <> swdocumenttypes_e.swDocASSEMBLY Then
          2) This is my preferred method, as it allows for more flexibility and cleans the code up, you don't have to call all 3 out, but it doesnt hurt (in case you need to access them later)
          Select Case Model.GetType
               Case swdocumenttypes_e.swDocASSEMBLY
                    'Do Something
               Case swDocumentTypes_e.swDocPART
                    'Do Something
               Case swDocumentTypes_e.swDocDRAWING
               case else
          end select
              Michael Jeffries
              I typically create a module and add the following subroutine(s) to ensure that solidworks is loaded, and that it has the most recent active document reference (copied and pasted from my module).  Before most operations, I'll call the LoadActiveModel() sub to make sure the reference is set and up to date:
              Imports SldWorks
              Imports SwConst
              Public Class Module_swCustom
                  Dim swModel As ModelDoc2
                  Dim swDraw As DrawingDoc
                  Dim swPart As PartDoc
                  Dim swAsm As AssemblyDoc
                  ''' <summary>
                  '''Sets the Active Object Model Reference
                  ''' </summary>
                  ''' <remarks></remarks>
                  Sub LoadActiveModel()
                      Select Case swApp Is Nothing
                          Case True
                              swApp = New SldWorks.SldWorks
                      End Select
                      swModel = swApp.ActiveDoc
                      Select Case swModel.GetType
                              swDraw = swModel
                              swPart = swModel
                          Case swDocumentTypes_e.swDocASSEMBLY
                              swAsm = swModel
                          Case swDocumentTypes_e.swDocNONE
                              'Nothing
                      End Select
              end class
