I recently was trying to figure how to make preset tables for solidworks so that I wouldn't need to input the Radius, K-Factor, and Thickness every time. I looked at the tutorials didnt really help. I also looked at the sample tables but they dont give enough information to know what is what. I have a partial clue that thats what the gauge table is for, I messed with it for a little bit, but still I'm pretty confuse. I just want to have presets so that all I have to do is click the name on the table for example that was aluminum with the certain tooling, then in the Sheet Sheet Metal Parameter for thickness .05 comes up and the inside radius turns to .05 and for k-factor it goes to .4
Kindest Regards,
Michael Jensen
check the attached table which I've create for aluminum bending ... hope it will help you to understand the concpet!
Mazen
