when I press tab while inserting a component into pipe routing sketch such as Tee, I got two alternatives, what if I need one of the other two alternatives, is there is any quick method rather than "Move Fitting with Triad" after inserting the component.
EDIT: Shift+arrow key
If you go to Routing=> Routing Tools=>Routing Options Setup=>Component Rotation Increment
you can change the default of 15 deg to a more practical 45 deg
You will also find a setting to automatically bring up triad upon drop in the next setting down.
