Hello I'm New,
I'm trying to create a plane with multiple referance for one sketch (ie: I need a plane to be at 112deg in the x,y and 12deg in the x,z) is it possible or not. Thanks for your input.
Jeff, create three different points which can give you desired angle and use them for creating the plane.
You can also create two different sketch with 112 in both the planes and then use point from them to create the plane.
