Dear All
I have this error of defining Elastic modulus in material properties when i click run in simulation how to solve this problem please help
Regards
Susheel
Are you using a custom material?? If yes then check the material properties for that material.
Hi Deepek
Thanks for your quick response
Nope i am using material from Din standards folder in solidworks and I have this assembly with 10-12 parts with some different Materials
Try changing the material for all parts to same material (for a test) and run the simulation. If study runs OK, then start changing the material one by one and finally find the material causing the issue. Check that material.
