BTW, it has to be noted!!!!
It's very sad knowing it takes another program (which is not
being used in todays market, another sad story) that can EASILY
import and export thess files!
Any body can give me experience about convert iges to
solidworks ?
I have some iges file. Some file convert correctly another
one solidworks just import the sketch not 3d model.
Try import these two files, please.
Give suggestion and comment.
They look like skeleton files form Pro-E. According to
Solidworks, the files didn't contain any surface data. I'd start by
checking your export source. What program generated the iges files?
John
The files where created in Catia V5 r16. You can tell this by
opening the IGES file in Notepad or Wordpad. IGES and STEP files
are just ascii text files that run through the appropriate
translators. See the first view lines of the file below.
START RECORD GO HERE. S 1
1H,,1H;,20HCNEXT - IGES PRODUCT,19H61725_D40D0_NP_.igs,44HIBM
CATIA IGESG 1
- CATIA Version 5 Release 16 ,27HCATIA Version 5 Release 16
,32,75,6, G 2
75,15,5HPart2,1.0,2,2HMM,1000,1.0,15H20060814.193444,0.001,10000.0,12HhaG
3
The output for iges and step translation success is very
dependent on the setting your customer used when translating the
file. I would see if they can send step files instead.
on 2006 19 18:29 John F. wrote:
> I am sorry John......
> That file is from my client. I don`t what is the
software that created that file.
> I am didn`t ask my client yet.
> BTW, could you give me some IGES file that produced by
Pro-e or UGII ?
> I will try it.....then inform you the result.
> Thank`s
It's very sad knowing it takes another program (which is not being used in todays market, another sad story) that can EASILY import and export thess files!
