Hello All,
I am newbie to SW but was assiged to make some simple udpates to the existing SW drawings. Hope anyone of you can provide me some help on this:
First of all, I need to change some part numbers in a exising 123.sldasm drawing. The 123.sldasm drawing contains total 13 major components and I need to change the part numbers for 5 components. How should I do it? Can you direct me to some instrustion or SW user's manual?
Secondly, after the change stated above done, how do I update the BOM (shown on 123.slddrw drawing) automatically?
Thank you so much for the help in advance.
Kent
Hi Kent,
just in case you want to rename the files, open a windows explorer to locate them and select one, right click and select solidworks and then rename,
remember that you need to rename both files part and drawing (OR assembly and dwg) of every single part number.
hope this helps.
