I'm having a problem with the date field changing to the previous day every time the data card is saved. For example, if I start off with a date of 10/15/12, then if I edit another variable in the data card and save it, the date automatically changes to 10/14/12 after selecting off the file and then selecting the file again. If I were to directly change the date field itself to 9/15/12, select off the file, and then selcet the file again, the date gets changed to 9/14/12. Does anybody have any idea why the date keeps changing on its own?
I suspect this is due to the Word template you are using.You can attach the problematic template here.
Regards
Ravi T
