2 Replies Latest reply on Nov 17, 2014 11:19 AM by Paul Mak
    Sketches to curves
    Brad Reinagle
      I have a part that will have a linear scale screen printed onto a surface.
      Our art department created the graphics for this scale and saved them as .dxf files.
      I can import these .dxf files into my model and they come in as a sketch which looks ok.
      I need to send these finished models to a supplier who does not have Solidworks so I save the files as .stp files.
      The problem is I do not see anywhere in the STEP file options to include sketches with the model.
      I cannot convert/project these sketches as curves as they are basically a bunch of short horizontal lines (think of a ruler). And I get a warning exuse about the sketch not being suitable to create projected curve due to it has more than one open/closed profiles.
      I could create a single curve, and then pattern it along the length that I need, but Solidworks does not let you pattern/mirror anything that has to do with datums, curves or points.
      Any other optionsto create geometry on this surface that will make it through the step file process?
      Thanks.
