0 Replies Latest reply on Oct 25, 2012 9:43 AM by Mahesh Cp
    How to Assign a find/balloon number at Assembly Model level to reflect at Drawing
    Mahesh Cp
      Assigning a find/balloon number at Assembly Model level to reflect at Drawing
      I need to make an assembly and drawing based on the customer input drawing with balloons on it. I would like to Assigning a find/balloon number at Assembly Model level to reflect at Drawing .
      Conditions: I don’t want a particular part model balloon number to be a file property or system property because I use this part model in several other assemblies where the balloon number is different.
      I should be able to assign this balloon number while putting these part models together to make an assembly model (so I don’t have to go to drawing and re assign the balloon numbers)
      If found a solution, this is a very time saving/handy for the big assemblies and drawings where you just make a drawing and hit a button asking to bring those balloon numbers assigned at assembly model over the face of the drawing.
      Looking for a best possible solution (or any other alternative options).
      Mahesh
