2 This error is actually driving me crazy !
I am trying to install solidworks 2012 sp. 4 onto my windows 7 32 bit laptop .
Everthing was going fine and then it hit the error !
The error is as following :
Internal error: The Windows Installer for this product component did not run as expected: 0.
Contact Technical Support.
When contacting Technical Support about installation issues, you will need to provide the installation log files available in this directory. Use the button below to save your logs as a zip file for sending to your support representative.
This is while im trying to install visual studio tools .
There is a option to skip this and continue on installing , I tryed to do this and got the following error :
Internal error: The Windows Installer for this product component did not run as expected: 1903.
Also i have tried many solutions like regestiry edits and installing the preq before hand
Thanks for any help
Lewis
Welcome to SolidWorks forums Lewis.
Please check solution id S-057711 in SolidWorks Knowledge Base for a possible solution.
You might also find this post helpful for your future reference.
