Is it possible to give a "user specified name" using a design table. I am pretty sure I already know the answer...
Deepak,
I added the $PARTNUMBER and custom description in my DT . and after routing the "User Specified Name" in the Configuration property is showing the part number I added in the DT. When I go to my BOM the custom description I add in my DT is showing but the Part No. is not showing the $PARTNUMBER. instead it is showing something like "3 in, Schedule40", "3 in, Schedule40, 1" , "3 in, Schedule40, 2" etc..
I do not know what I did incorrect! and at this time I couldn't find any solution other than renaming the Part numbers manually in my BOM.
do you have any subjections?
Yes, the header will be $PARTNUMBER
Attached is an example from SW2012.
