I am having questions about line behavior in SoildWorks. I tried to learn sketching and of course what I should be expecting from line but found there are different cases and it is not consistent.
Here are few of the cases:
Case 1: let's assume there are two lines connected via a shared node e.g. AB and AC so moving AB allows us to move AB on AC and as much as it gets extended in 2 directions or moving AC allows us to move AC on AB only.
Case 2: If we add up a new line to the same shared node between AB and AC then we will fact two different behaviors:
2-1) if line gets branched out then other 2 lines movement will stay as before
2-2) if line is added toward sharing node then other 2 lines or at least one of them will have a different behavior meaning that one of them will move in favor of new line.
in cases more than 2 lines, this gets more complicated.
Question: What is the logic behind this?
akohan
Amit,
I think you're going to have to provide some images so we can better understand what you're trying to describe.
