hello all,
i have been reading some of the posts in this section to help with my problem but not found quite the right one.
I have downloaded the iso zip file in the SW contents section on the right. i removed the profiles from that folder and inseted them into the original folder from where the weldments come from. nothing changed thow when i went to insert a structual member. so i even went back and deleted the originl 6 that where there thinking they would disapear but there still there.
do i have to update SW whenever i do something like this or is something im doing terribly wrong?
help asap?????????
thanks in advance to any help
i'm not quite sure i understand.
it might be best to leave the default profiles alone.
the folder structure i.e. depth/levels must be maintained
unzip the profiles and add the location to
tools> options> system options> file locations> weldment profiles
ansi inch is included with the zip file.
because the folder "ansi inch" exists in the default location one of them must be renamed.
or remove the default location from your file locations (which is what i did).
