6 Replies Latest reply on Oct 19, 2012 9:08 AM by Brad Reinagle
    Relations? how to show them and disable them?
    Brad Reinagle
      I am working on a model we recieved from a design contractor.
      I am changing some features on this model.
      This part has a Shell feature and then some Ribs in it.
      There appears to be some sort of relationship between the Shell thickness and the Rib thickness, as when I change the thickness of the shell the thickness of the ribs changes also.
      In Pro/E this is set by Relations, which the user writes and controls, and can display them to add, edit or delete them.
      Where you can make one dimension value equal another feature's dimension outside of sketching etc.
      What is this kind of control called in Solidworks and how do I access it to kill this relation?
