Converting a tube to Sheet metal problem!
Question asked by Peter Muesch on Oct 17, 2012
Latest reply on Oct 22, 2012 by Danny Pearson
Scenario #1.
I create a 1" rd tube as a solid and put a 3/8" thru hole in the center of the tube. Then add a .001" cut down the center of the tube so that I can convert the tube to sheetmetal.
Scenario #2.
I create a 1" rd tube as a sheetmetal part and use base flange tab. Then put a 3/8" thru hole in the center of the tube.
Result.
The ending result is, two totally different holes.
You would think that I would get the same end result right??
Well it's not and it has caused some major issues at work.
Is there a reason Solidworks can't figure the hole out right??
I have attached the files and a pdf on how the holes look differently.
Does anybody know why this happens?
