Hi Friends,
I am simulating a closed shell model which is being heated from outer surface kept at some ambient temp......
Over the period of time there will be some trapped heat or heat pockets inside the closed shell....my question is, how do i include this effect of trapped heat/heat pocket into simulation to get accurate results.
Vinay
Hi Vinay: are you trying to model air that might be heated via convection from the interior walls of the shell? If that is the case, you will likely need to use the SolidWorks Flow Simulation product.
