So I am working on designing a car to test air resistance for a school project, but I ran into a problem. I am putting the headlights on a curved surface, and using Wrap, and it resizes the sketch. Is there a way to lock the sketch so it will not get smaller around a curved surface?
Album here with pictures of it before and after I Wrap it
Kyle
Antonio is talking about sketching and probably doesn't understand what you're asking.
For what you're describing you probably want to use a cut extrude with the end condition set to 'offset from surface' with 'translate surface' and 'reverse offset checked' instead of wrap.
Wrap preserves the lengths of curves, so the footprint of a wraped sketch is smaller on a curved face than on the flat plane it was drawn on..
Good luck.
