Hello all,
I am modelling a series of pendula, which I want to animate.
I am using Motion Analysis to get the most realistic application of gravity on the pendula.
What I want is for each pendulum to begin its motion at a different time during the animation (first one right away, then the second one a few seconds later, etc.)
But what I am finding is that I cannot add key points and "tween" animations in Motion Analysis.
When I add them, I get a mouse-over message that says they don't work except in "Assembly Motion studies" (see attached image)
Dragging components and adding Key Points works fine in Animation mode, but gravity is not available.
Is it really impossible to use gravity and key points in one animation?
Any advice on how to make a component move and then be effected by gravity partway through?
I am baffled. Any help would be warmly received.
I am using Solidworks 2009.
Ben
Welcome to SolidWorks forums Ben.
Did you tried switching to Basic motion option instead of motion analysis (click on the arrow next to motion analysis and pick basic motion from the drop down).
Also what kind of key you're trying to place. Can you upload your files here to check.
Please use "advanced editor" in case you want to attach any files.
You might also find this post helpful for your future reference.
