TWTrevor Wunn11/10/2012
Hey All,
I would like to have a macro that will delete an old rev table, create a new one with my information, and then attach it to the anchor point i have set in the upper right corner. I was looking over the Get and Set Table Anchor of Hole Table section of the solidworks help and was able to decipher some of but I don't understand enough of it to get the anchor part of it to work. The rest of it, however is working quite well. Any help would be greatly appreciated.
Trevor
Here is the code I have, anything related to the anchor is just thoughts and may not be correct.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
'Delete Old Custom Properties
Dim modelDoc As SldWorks.ModelDoc2
Dim CustomPropertyMgr As SldWorks.CustomPropertyManager
Dim current_Date As Date
Dim user_Name As Boolean
Dim Todays_Date As Boolean
Dim temp    As String
    Set modelDoc = swApp.ActiveDoc
    Set CustomPropertyMgr = modelDoc.Extension.CustomPropertyManager("")
    current_Date = DateValue(Now)
    CustomPropertyMgr.Delete "DrawnBy"
    CustomPropertyMgr.Delete "DrawnDate"
    CustomPropertyMgr.Delete "CheckedBy"
    CustomPropertyMgr.Delete "CheckedDate"
    Todays_Date = modelDoc.AddCustomInfo3("", "DRAWNDATE", swCustomInfoDate, current_Date)
    user_Name = modelDoc.AddCustomInfo3("", "DRAWNBY", swCustomInfoText, "TREVOR W")
'Delete Old Rev Table
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("DetailItem413@Sheet1", "ANNOTATIONTABLES", 0.1376164711627, 0.2081344372716, 0, False, 0, Nothing, 0)
Part.EditDelete
'Insert New Rev Table
Dim currentSheet As Object
Dim myRevisionTable As Object
Set currentSheet = Part.GetCurrentSheet()
Set myRevisionTable = currentSheet.InsertRevisionTable(False, 0.2699418663596, 0.2060257654404, 2, "C:\KMI-Vault\Admin Files\SW - Templates\TABLES\KRAUSE REV TABLE.sldrevtbt")
'Add Rev A and Description
Dim myTable As Object
Dim nrows As Integer
Dim msgResult As Boolean
Set myRevisionTable = currentSheet.RevisionTable
Set myTable = myRevisionTable
If myTable Is Nothing Then
msgResult = MsgBox("No Revision Table on Drawing", vbCritical)
Else
    nrows = myTable.RowCount
    If nrows = 3 Then
        'end
    Else
        longstatus = myRevisionTable.AddRevision("A")
        myTable.Text(nrows, 2) = "TREVOR W"
        myTable.Text(nrows, 3) = current_Date
        myTable.Text(nrows, 1) = "INITIAL RELEASE"
Dim swRevTable As SldWorks.RevisionTableAnnotation
Dim rev_Anchor As TableAnchor
Set rev_Anchor = drwView.Sheet.TableAnchor(swTableAnnotation_RevisionTable)
Dim anchorPosition
anchorPosition = rev_Anchor.Position
'myTable.Postition = swBOMConfigurationAnchor_TopRight
