6 Replies Latest reply on Oct 24, 2012 11:23 AM by Chris Sparber
    Extracting data from a drawing
    Chris Sparber
      Hello All--
      I have my drawing template set to use configuration specific properties from a selected view to populate the drawing name and drawing number.  Then revision is a user input and the created date is a sw custom property.  Is there a way to pull that data out of the active sheet document fields and put it onto an excel sheet?  Thanks!!
        • Re: Extracting data from a drawing
          Michael Jeffries
             Yes there is!  Just keep in mind you need to change the .CustomInfo("") to your custom parameter name, the attached code should do exactly what you want!  You need to go to References and add the Microsoft Excel Object Type Library for the excel functionality to work.
              Dim swModel As ModelDoc2
              Dim PartNum, DateCreated As String
              Dim xlApp As Excel.Application
              Dim xlBook As Excel.Workbook
              Dim xlSheet As Excel.Worksheet
              Sub Main()
                  Set swApp = New SldWorks.SldWorks
                  Set swModel = swApp.ActiveDoc
                  Debug.Print("******** Time Stamp: " & Date.Today & " ************")
                  PartNum = swModel.CustomInfo("Enter your Custom parameter Here")
                  DateCreated = swModel.SummaryInfo(swSummInfoField_e.swSumInfoCreateDate)
                  Debug.Print("Part Number: " & PartNum)
                  Debug.Print("Date Created: " & DateCreated)
              Sub ExcelStuff()
                 Set  xlApp = CreateObject("Excel.Application")
                 Set xlBook = xlApp.Workbooks.Add()
                 Set xlSheet = xlBook.Worksheets(1)  'First worksheet in workbook
                  With xlSheet
                      .Cells(1, 1).value = "Instance"
                      .Cells(1, 2).value = "Part Number"
                      .Cells(1, 3).value = "Date Created"
                      For i = 2 To 11
                          .Cells(i, 1).value = i
                      .Cells(2, 2).value = PartNum
                      .Cells(2, 3).value = DateCreated
                  End With
                  xlApp.Visible = True
          End Class
            Chris Sparber
            Mike the variable comes from the part configuration specific properties.  When I set up my drawing template I set the drawing title and part number to populate based on the part properties in a selected view.
            Thanks Deepak for the two examples.
            I understand how to assign note identities to fields in the title block (done automatically); however, I am not sure how to assign a name to an annotation that you put on your drawing.  How do you assign a name to an annotation on the drawing sheet?  Thanks.
                Chris Sparber
                I found that using notes within a titleblock is highly efficient.  I can also use configuration specific properties from parts in specific views on the sheet to automatically populate the values.  This takes me out the business of manually creating excel spreadsheets to manage the drawings for specific projects.  Thanks.
