I am having some issues with our shared toolbox. My support from our Vendor seemed lacking if I must say so. He had no idea why we would want to use a shared library over each having a single user one.
Any way...I am constantly getting failed to save error. I constantly have the ~ with the file name in the actual directory. That means that the file is open and being used. It should not be doing this should it? I was under the understanding that Solidworks only made the document non-read only when you go to save an a new component in it, otherwise it was read only so that everybody could add and not have the issue I am having. I physically watch my folder fill up with the temp files while another guy opened an assembly.
Is there any good and detailed information out there on how to set up solidworks toolbox properly in a multi user environment.
Mitch
Mitch,
Do you have sw profesional and if so it is simple. Save a copy of the solidwworks data folder onto a shared drive. then point your toolbox location to it under //system options / holewizard/ toolbox(make sure that all of your users do the same thing.
You can configure it under toolbox configuration to add your part #s and descriptions or you can add then as you go in the toolbox drag and drop menu.
