I am having a problem with making part in an assembly independent when I have copied a part(using copy with `mates) multiple times. So far from my trials this only happens on the 3rd, 5th and odd multiples thereafter.
Is this known about or is there a simple work around?
do you mean making an instance of a virtual component independent?
If so, you should report that to your var.
