any ideas how to get the flange to go up round the other edges?
thanks in advance
thanks in advance
You will have to create a separate Edge Flange for each of the angled edges. The underlying sketch profile will also have to be adjusted to create the mitred joints.
have tried seperate edge flanges but its a sod to get em to line up.
what do u mean by underlying sketch?
This is a real interesting part.
After downloading your step file and converting to sheet metal, I added individual flanges to come up with this:
As Kevin mentioned, by editing the flange sketch I was able to adjust the shape. Right click on the Edge Flange feature and select the Edit Sketch icon. If you make the sketch for the preceeding flange visible you can then apply some Parallel and Equal constraints between the adjacent edges of the preceeding and current flange sketches.
If you dig into the part I've uploaded you can sse how I did that.
Tony,
I took a look at this one and it's a challenge. I think I might consider making the side (that you need) out of one piece, kinked and knotched as required so you can weld the joints on the bottom where you now have bends. In other words, do it the other way around.
Just a suggestion. (Can I hear you telling me to go to hell? LOL!)
can you make a solid part in the completed shape that you are looking for so i have a better idea about the final configuration?
Hey Tony Edmunds,
Not sure if there's a straight forward method with just a few clicks but this is my version. Hope this is what ur after.
Note: didn't put in the holes/cut extrudes.
God Bless
Alexander
Found that with Kelvin Lamport's version, im able to replicate it and tweak the settings in 'Convert to sheet metal' a little to give a closer gap tolerance. Would say his version is a far simpler way of doing this.
Tony,
Any way you can post a picture or STEP file? I get the "future version" message when I try to open your part file.
