Attached is a model I made that I need to platten so I can cut the pattern. Is there a way to accomplish this?
Thank you,
Steve
Thank you,
Steve
Steve's part will flatten just needs some help on modeling technique.
I woud create the part in halves. Also added a surface and thickened, this will give you normal cuts and keep material thickness constant. Use Insert Bends instead of Convert to Sheet Metal.
Also watch your Cut-Extrude3 sketch. I constained it to the origin, it was skewed a bit.
Cheers,
Anna
Steve,
I didn't try opening your model (no time!). It might help if you posted a picture. If your part requires the material to be drawn, then SolidWorks can't flatten it. Normally it only flattens parts that can be bent in a press.
Jerry S.
