I insert a countersunk bolt from the toolbox.
I made holes with 45 degree chamfer, but when i try to impose a coincident constraint between the chamfer and the conic face of the bolt-no.
Use Hole Wizard to create your holes. It will make your life much easier when it comes to inserting fasteners. You will then be able to use Feature Driven Patterns for populating your flat head screws.
Flat Head Screws use an 82 or 100 degree included angle. Confirm what this is for the fastener you choose to insert from Toolbox.
EDIT: Or 90 degree included angle for metric..... Thanks Dwight
Cheers,
Anna
Hi Karol,
Angle is different. Try with 49 deg for Chamfer.
Adrian
