I use a lot of models provided by equipment suppliers in my assemblies and these are often provided as .swb macros.I generally save the macro into the appropriate project sub-directory and then run it to generate the part. The macro requests a save location, which means clicking all the way down the folder structure until I get to the appropriate folder/directory to save the part into, which gets tiresome after a bit. It would be a lot easier if I could automatically save to the macro location. Is anyone aware of a setting within sw that might allow this ?
In the attached macro you need to modify these line found under Sub main()
to
