Hello All---
I just defined all of the design libraries in pdm workgroup's admin interface. The vault and design library are on the same CAD server. I ran a test and tried to check in some of the individual parts that I was going to be using in a larger assembly as a test to see if the references were working. When doing so I got the error that said, " Cannot check in because admin does not allow check in of library components." Then I used those same parts in a larger assembly. I went to save and check in the larger assembly and the vault only recognized 2 out of the five or so design library parts. Has this happened to anyone before?
Thanks.
Sincerely,
Chris
Hello All--
This was actually caused by a copy of the library part being in the same local directory as the assembly I was trying to check in. The vault will not recognize the library part if a copy of the part exists in the local directory.
Sincerely,
Chris
