SRSeth Ruhan21/09/2012
Gday,
I am quite new at Solidworks API & learning it API is quite a shock to the system.
My current problem is as follows.
I want to get the distances maximum & minimum between two faces.
To do this, I assume I will need to ilterate between all points on each face getting the min and max from both.
So starting on item 1. I pick a point on face1, and a point on Face2. However I want the distance between the two points normal to Face1.  This is where I am stuck.
Below is the code I think I will use, However since I don't know what im doing I could be way off.
All so prt file has a sketch with three dimensions, this is what I am trying to achive.
For Each Face As Face2 In allFace
            Dim Edges() As Edge = Face.GetEdges
            Dim Points() As Point3d
            For Each edgeFace In Edges
                Dim SVertex As Vertex = DirectCast(Edges(1).GetStartVertex(), Vertex)
                Dim EVertex As Vertex = DirectCast(Edges(1).GetEndVertexetStartVertex(), Vertex)
                ReDim Preserve Points(Points.Length + 1)
                Points(Points.Length - 1) = New Point3d(DirectCast(SVertex.GetPoint(), Double()))
                'Points(Points.Length - 2) = New Point3d(DirectCast(EVertex.GetPoint(), Double())) end point will be another items start point.
            Next
            For Each Face1 As Face2 In allFace
                Dim Points1() As Point3d
                    Points1(Points1.Length - 1) = New Point3d(DirectCast(SVertex.GetPoint(), Double()))
                    'Points1(Points1.Length - 2) = New Point3d(DirectCast(EVertex.GetPoint(), Double())) end point will be another items start point.
                Next
            Next
            For Each Point As Point3d In Points
                'compare point & Face against all in points1
            Next
            ' Dim vTessTriangle As Object = Face.GetTessTriangles(True)
            ' ProcessTessTriangles(vTessTriangle)
        Next
