2 Replies Latest reply on Sep 28, 2012 10:06 AM by Phil Perlich
    Fluid volume in Simulation
    Olutoba Olakanye
      Am trying to do a live load to include the fluid volume in a vessel. please can anyone tell me how to add the weight load when filled with fluid?
        • Re: Fluid volume in Simulation
          Anthony Botting
          Hi Olutoba: For static you can use "remote load" if you know the weight and CG location. Create a coordinate system at the CG for easy selection. You can select the interior surfaces of the vessel and choose the reference coordinate system at the CG, and the direction of the weight relative to that coordinate system. Software will distribute the force uniformly on the surfaces. A symbol for the force will show at the CG, and you'll see purple colored leaders extending to the surfaces of the vessel.
          Alternatively, you could just apply the standard "force" on the interior vessel face and specify a direction. The software will distribute the load uniformly to the interior faces of the vessel, but the effective location of the force will be at the geometric CG of the selected surfaces.
          If it's a vibration problem you're doing, you will have to specify a "remote mass", instead of a force. Hope that helps.
