I keep getting the following error when trying to do static analyses.
Fatal Error: c00ce501: line: 13, column 8
Missing equals sign between attribute and attribute value.
It isn't an issue with the part since the error continues comes up when I create a new model/simulation.
It appears to pop up for every body in my multibody weldment parts. So on larger weldments I have to click ok many times to get to the simulation.
Further, stress and strain plots show up blank. The displacement plot works and shows deformation created from the applied forces, but the model disappears and the colour legend goes from 0 to 0 for max/min stress and strain.
Well, I managed to solve one of my issues. A setting in the part template file was causing the node errors, and simply recreating the part template solved the pop up messages.
Now I'm still stuck trying to get these invisible weldments to display.
(edit) solved my other problem. I have to select either "solids and shells" or "beams" in the stress definitions.
