10 Replies Latest reply on Dec 16, 2017 12:32 PM by Oleg Bezyaev
    Insert Hole Table
    Yateen Shembade
      I am trying to create a Macro to insert a HoleTable in a drawing view.
      Can any one tell me if there is a way to insert a hole table by just selecting a vertex in the view.
      Api will select all the faces i that view and insert a hole table using selected vertes and faces.
      Set swView = swSelMgr.GetSelectedObjectsDrawingView2(1, -1)
      Set swHoleTable = swView.InsertHoleTable2(False, 0.011, 0.545, swBOMConfigurationAnchor_TopLeft, "A", "C:\Program Files\SolidWorks 2012\SolidWorks\lang\english\standard hole table--letters.sldholtbt")
        • Re: Insert Hole Table
          Artem Taturevych
          Yes, use the View::GetVisibleEntities method. Refer the following example in API Help Documentation that will help you:
          Get All Edges in Visible Component in Drawing View (VBA)
          Get Visible Components and Entities in Drawing View (VBA)
          ______________________
          Regards,
          Artem Taturevych
          Application Engineer at Intercad
          http://intercad.com.au/
          Tel: +61 2 9454 4444
              Yateen Shembade
              Artem
              Thank you for your reply. However I wasn't able to get holetable through that method.
              I am not sure what I am doing wrong.
              Presently, I am selecting a point in a view and running my macro.
              It puts the origin at that point, but does not select any face in that view.
              I am not very sure what I am doing wrong.
              This is my code:
              Set swDrawModel = swApp.ActiveDoc
              Set swModelDocExt = swDrawModel.Extension
              Set swSelMgr = swDrawModel.SelectionManager
              Set swView = swDrawModel.GetFirstView
              Set swView = swView.GetNextView
              Set swView = swSelMgr.GetSelectedObject5(1)
              Set swHoleTable = swView.InsertHoleTable2(False, 0.011, 0.545, swBOMConfigurationAnchor_TopLeft, "A", "C:\Program Files\SolidWorks 2012\SolidWorks (2)\lang\english\standard hole table--letters.sldholtbt")
                  Artem Taturevych
                  Please find the attached sample. It will create a hole table for the all faces within view of preselected vertex. The vertex will used as origin.
                  Regards,
                  Artem Taturevych
                      Yateen Shembade
                      I am using this macro for a while now.
                      Recently I realized, this macro is selecting counter bore hole as an another surface.
                      I am seeing two callouts for the same counter bore hole.
                          Artem Taturevych
                          Can you post the sample picture and file? I'm not sure what do you mean.
                          Regards,
                          Artem Taturevych
                            Keith Rice
                            Yateen,
                            The reason you are getting two callouts for a counterbore hole is that a counterbore creates a new face in the part that is picked up by IView::GetVisibleEntities. Since Artem's macro is creating a hole tag for hole wizard holes associated with EVERY face, the counterbore hole is tagged twice---once for the "main" face and once for the face created by the counterbore.
                            So what you can do is add, within the second For-Next loop, a conditional statement testing whether that face belongs to a hole wizard feature.  Here is a version of the macro similar to what Artem provided that includes that conditional. Please change the BOM template path to the appropriate path on your computer:
                            Const BOM_TEMPLATE_PATH = "C:\Program Files\SolidWorks 2012\SolidWorks\lang\english\standard hole table--letters.sldholtbt"
                            Dim swVertex As SldWorks.Vertex
                            Dim swEnt As SldWorks.Entity
                            Dim swFace As SldWorks.Face2
                            Dim swView As SldWorks.View
                            Dim swFeat As SldWorks.Feature
                            Dim swHoleTable As SldWorks.HoleTableAnnotation
                            Dim swHoleTableFeat As SldWorks.HoleTable
                            Dim swSelData As SldWorks.SelectData
                            Dim vVisibleComps As Variant
                            Dim vFaces As Variant
                            Dim i As Integer
                            Dim j As Integer
                                Set swModel = swApp.ActiveDoc
                                Set swSelData = swSelMgr.CreateSelectData
                                Set swVertex = swSelMgr.GetSelectedObject6(2, -1)
                                Set swEnt = swVertex
                                vVisibleComps = swView.GetVisibleComponents
                                swSelData.Mark = 1
                                swEnt.Select4 False, swSelData
                                For i = 0 To UBound(vVisibleComps)
                                    vFaces = swView.GetVisibleEntities(vVisibleComps(i), swViewEntityType_Face)
                                    For j = 0 To UBound(vFaces)
                                        'Determine if the face was created by the hole wizard; if it is then ignore it, otherwise mark it
                                        Set swFace = vFaces(j)
                                        Set swFeat = swFace.GetFeature
                                        If swFeat.GetTypeName2 <> "HoleWzd" Then
                                            Set swEnt = vFaces(j)
                                            swSelData.Mark = 2
                                            swEnt.Select4 True, swSelData
                                    Next
                                Next
                                swView.InsertHoleTable2 False, 0, 0, swBOMConfigurationAnchor_BottomLeft, "A", BOM_TEMPLATE_PATH
                            By the way, I also noticed that if you leave the last argument of IView::InsertHoleTable2 empty (a zero-length string), then the first hole tag is "1" and not "A1". This is corrected, I found, by actually specifying the hole table template path.
                            Hope that helps.
                            Keith
                            Video Tutorials for the SolidWorks API
                                Yong Ning
                                Why don't insert Hole Table?
                                ' Preconditions:
                                '         (1) Drawing is open.
                                '         (2) A view in the open drawing is selected.
                                ' Postconditions: A hole table is inserted in the drawing at the point where the
                                '         view was selected.
                                Option Explicit
                                Public Enum swBOMConfigurationAnchorType_e
                                    swBOMConfigurationAnchor_TopLeft = 1
                                    swBOMConfigurationAnchor_TopRight = 2
                                    swBOMConfigurationAnchor_BottomLeft = 3
                                    swBOMConfigurationAnchor_BottomRight = 4
                                End Enum
                                    Dim swTable                 As SldWorks.TableAnnotation
                                    Dim swAnn                   As SldWorks.Annotation
                                    Dim vPickPt                 As Variant
                                    Dim nNumCol                 As Long
                                    Dim nNumRow                 As Long
                                    Dim sRowStr                 As String
                                    Dim i                       As Long
                                    Dim j                       As Long
                                    Dim bRet                    As Boolean
                                    vPickPt = swSelMgr.GetSelectionPoint(1)
                                    Stop
                                    ' View::InsertHoleTable
                                    '   datum     --> 1
                                    '   X axis    --> 4
                                    '   Y axis    --> 8
                                    '   hole      --> 2
                                    '"C:\Program Files\SolidWorks\lang\chinese-simplified\hole table--tags combined--numbers.sldholtbt"
                                    'View.InsertHoleTable 0, 0.150505, 0.114403, 1, "C:\Program Files\SolidWorks\lang\chinese-simplified\hole table--tags combined--numbers.sldholtbt"
                                    'Set swHoleTable = swView.InsertHoleTable( _
                                                        False, _
                                                        vPickPt(0), vPickPt(1), _
                                                        swBOMConfigurationAnchor_TopLeft, _
                                                        ""): Debug.Assert Not swHoleTable Is Nothing
                                    Set swHoleTable = swView.InsertHoleTable(0, 0.15, 0.1, 1, "C:\Program Files\SolidWorks\lang\chinese-simplified\hole table--tags combined--numbers.sldholtbt")
                                    Set swTable = swHoleTable
                                    Set swAnn = swTable.GetAnnotation
                                    nNumCol = swTable.ColumnCount
                                    nNumRow = swTable.RowCount
                                    ' List table contents
                                    For i = 0 To nNumRow - 1
                                        sRowStr = ""
                                        For j = 0 To nNumCol - 1
                                            sRowStr = sRowStr & swTable.Text(i, j) & ","
                                        Next j
                                        Debug.Print Left(sRowStr, Len(sRowStr) - 1)
                                    Next i
                              Oleg Bezyaev
                              Hi Artem! is there any options to select vertice by code? How to find vertice?
