hi,
In attachment is a assy of a hydraulic cylinder I made.
Afterwards I want to put a design table behind it for the different models and lengths.
For some reason I can't put this assy to "flex".
Always "sub-assemblies with layout sketches must be kept ridgid"
I did not make any layout sketches! Al the parts are made separately , then assembled.
main assy is N0058-003-000
thanx for any suggestions
nico
Open the sub-assy, then right click on the assy name in the feature manager and under layout, select delete from the list. Then you should be able to set the sub-assy to flexible.
BTW the symbol next to the assy name suggests indicates that you might have started a layout sketch.
