Issue with Plane rotation
Question asked by Chris Kalnasy on Sep 18, 2012
Latest reply on Aug 27, 2013 by Andrew Brown
Essentially,
This has happened to me more than one time now and I cannot figure this out.  I need to rotate a plane 180 degrees so that my origin is essentially mirrored where it is on two of the axis.  The reason why is if I use the 'Normal To' command, the plane will be upside from where I want, and if I click it again, it will just flip to the opposite side, which is not a remedy to this issue.  I know if you have three points that make up a plane, you can select them in a opposite order and it will flip which side is the positive side of the plane, but in my case, I have one single point and the front plane for a reference.  Selecting them in reverse order does nothing.
Any help is surely appreciated.
