I'm putting together a sheet metal blower that has a Spiral part which requires a flat pattern. I was able to use the
sheet metal tools to flatten the spiral but cannot make the flange to the spiral flatten correctly. Centrifugal blowers
generally have a flange that lays flat on the side panel to the blower. I have included an example image showing
the small flange that folds to the side panel and the file that I am working on. I have only put on one flange up to this
point using a method that is not quite right for the flange to flatten correctly. I tried various things with the new Sweep
Flange tool and could not get it to work with the spiral. You will see if you unsupress Unfold1 and
Unfold2 in the tree the flange flattens but only on its edge as I knew it would. I'm basically fishing around for options
to something that may not have a solution. My hope is to get the flange to flatten with the spiral so it shows
correctly for flat developement.
