There was a valve I was trying to just scale down and it was all fine except the C and R points didn't scale down with it, I was able to move the C points and R points, but now it won't snap onto the route at all. Is there a way to just get the default valve back or is there a way to scale the whole part down including the points?
I was able to move the routing and connection points but I keep having this problem that comes up where I make a copy of a part, but both parts keep getting referenced in the assembly. So I'm trying to make two different parts by just copying one part and re-saving it, but no matter what I do they both end up getting changed and saved to the assembly i'm working on. How do I cut off the references so one part is its own part seperate from the one I copied it from?
