I'm trying to create a design checker check, but cannot get past the declarations. The thing that makes this REALLY frustrating is that I have copied code directly from the API help. Also, being a half-newb with this type of programming, I find the API help not very, erm... helpful. The example code below is from the Custom Check Document (VBA) section of the API help for SW2012. Edited for brevity.
My code always hangs at the line Dim dcApp As DesignCheckerLib.SWDesignCheck, with a Compile error: User-defined type not defined.
Code follows below, with the Runcheck function having been shortened for brevity, but otherwise this is a direct copy/paste of the example.
Dim nFailedItemCount As Integer
Dim bCheckStatus As Boolean
Dim errorCode As Long
Sub Validate()
' Validate document
bCheckStatus = True
Dim FailedItemsArr() As String
bCheckStatus = RunCheck(FailedItemsArr)
' Inform SolidWorks Design Checker about the results
Set dcApp = swApp.GetAddInObject("SWDesignChecker.SWDesignCheck")
errorCode = dcApp.SetCustomCheckResult(bCheckStatus, (FailedItemsArr))
Function RunCheck(ByRef FailedItemsArr() As String) As Boolean
RunCheck = False
End Function
