2 Replies Latest reply on Sep 11, 2012 4:15 PM by Alin Vargatu
    Error 1406
    Charles Jeune
      How can I fix this error when I open SolidWorks 2012
      I click Ignore twice and the program open.
        • Re: Error 1406
          Troy Peterson
          See this post
          • Re: Error 1406
            Alin Vargatu
            Charles,
            As per the Knowledgebase S-059061, even this error message is wrong.
            The full path to the problematic registry location is not indicated. Not only that, but the registry location identified is wrong. The registry location that is problematic is:
            HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SolidWorks\Licenses
            To resolve the 1406 error, modify the permissions of this key so that they are the same as its parent key. Or, delete this key (which may require modifying its permissions, first, to allow the deletion) and repair the SolidWorks installation to resolve the problem.
            Note: as indicated by the registry location, this problem is ONLY known to occur on 64-bit PCs.
