I found that when I am changing the angle of a line, it seems to rotate about another invisible point rather than its ends, as shown in the video below:
Please click the image for animation:
Could someone tell me how to make it rotate about its either end, or any aribtrarily point?
Qi
Fix one end of the sketch on the origin and then use the tool "Rotate Entities" in the sketch command manager or do it the way you are doing. But remember you need to fix one end of the sketch (the end around which you want to rotate the sketch).
Hope this helps
