Can I add menu items to ribbon or toolbar?
For example, I frequently use “Detach segment on drag”. In order to access I need to press ALT+T and then move the mouse cursors to “Sketch Settings≫Detach”, and after the operation I would repeat the process to turn it off. If the button can be put on ribbon or toolbar it would then save a lot of time.
Qi
You might be able to record a macro with that command and get that macro on a toolbar.
