surface continuity
Discussion created by Guest on Aug 27, 2006
Mark -
In my experience just setting a boundary for 'curvature' and pressing the button does not get me curvature continuity - when I use angular deviation to check, I see the resulting face doesn't even get c1 tangency. Have you had much luck with SWx curvature continuity?
I keep finidng the best results from lofting and manually adjusting the start and end tangencies, though (as you rightly point out) getting tangency along the sides is not a sure be and just trying can cause ripples/faults elsewhere in the loft. My models always end up looking like a states-map of patches as I try to fix one spot after another.
