1 Reply Latest reply on Sep 6, 2012 10:26 PM by Jerry Steiger
    Dxf text color
    robert dattilo
      Hello;
           I've opened a dxf, in SW, & it has yellow text, that, against the SW beige drawing background. I'd like to change the dxf's texts
      color , & I'm having some difficulty. It appears some of the portions, are blocks. Any ideas's that might help the process?
      Thanks, in advance;
      Rob_D SW 2012 sp4
        • Re: Dxf text color
          Jerry Steiger
          Rob,
          I'm not much of a dxf person or a block person (nor much of a drawing person, for that matter!), but you haven't been getting any responses from the experts so I will chime in. You might want to look at using layers, as that might let you change the color of all the text at once, whether in blocks or not. If that doesn't do the trick, you might need to explode the blocks.
          Jerry Steiger
